blind demodulation
is it possible to implement the "blind demodulation" in LabView 8.5 ?
If someone could give me some information about this topic
Thanks in Advance
Seb_MDI
Seb_MDI
France
(3,879 Views)
What do you mean by "blind demodulation" ? see here for a quick search in demodulation using LabVIEW.
Start wiring and post if you stuck up in anything.
Mathan
(3,874 Views)
i have a signal, and i would like to know what is the carrier frequency, the type of modulation and others things to do an analysis of this signal.
I have no idea about the type of modulation and his differents parameters, and i know there is a technic to find it ( a blind analysis)
do you understand my problem?
thanks
Seb_MDI
Seb_MDI
France
(3,869 Views)
Hello.
The modulation toolkit allows you to demodulate your signals, but you obviously need to know the type of modulation you have.
Regards.
(3,793 Views)
thanks,
i have the modulation toolkit, but i would like to know if is possible to implement a VI which could detect the type of modulation?
and then to module/demodule this signal.
Seb_MDI
France
(3,771 Views)
