block diagram printed in white & black mode
i want to print the block diagram inserted in word as pictures,it's just white and black print .
then a problem comes up:the light color was printed hazily.
so i wonder if the color of the block diagram can all be changed to black,at least the color of the words?
thanks for answers!
(2,874 Views)
If by "words" you mean the labels of the functions then all you have to do is hit ctrl+a while on the block diagram and select the desired font color.  This will update every label on the block diagram to have the font color you specify.
(2,868 Views)
thank you!
not only the labels but also the digits and the local viriables
i,m using LV7.1
(2,846 Views)
Using the select all method will also modify the font size and color of any "text" in a constant.  It will not change the font size or color of the text on a local variable, and I don't know of any way to do this.
(2,843 Views)
