blocks - to have on the block diagram, but not to execute
In standard programm languages there are possibilities to mark some lines in code not to execute them (for example, if we have written some code and want to use keep it in programm, but don't need to execute it right now)
e. g.
Does LabView allow to mark several blocks on block diagram, to have them on it, but not to execute?
Thank you in advance.
Anna
(2,370 Views)
Hi Anna,
in newer LabView versions you can disable parts of a block diagram by using the "Disable" structure. This will work even with unfinished, buggy code.
In older versions (pre-8) you can use a case structure to put the "not to be executed"-code in the not-executed case - but here the code has to be executable...
(2,369 Views)
thanks
(2,366 Views)
