bluetooth example setup question
Dear all,
 I start to play with bluetooth. I open the example from labview 8.0. I have no idea what I have to setup before this example can run. Please help. I have also tried to run the client with it, but does not work either
thanks
=Labview 7.0 & 8.0 & 8.5=
(3,412 Views)
Hi zmarcos,
The following link point out the requirements to use Bluetooth in LV.
http://digital.ni.com/public.nsf/allkb/B4C0FCC67BF4485486256F12005B6D61?OpenDocument
After checking this document, I will advise you to take a look in the developer zone Bluetooth tutorial linked above. It has a demo to run Bluetooth.
http://zone.ni.com/devzone/cda/tut/p/id/5323
Let me know if you have further questions.
Best Regards,
Alisson Kokot
NI BRAZIL
(3,398 Views)
I read the article, I see that my computer has to use the windowXP bluetooth stack. However, my dell notebook bluetooth card has its special driver. My I know whether the window xp stack will work on a USB bluetooth adaptar?
(3,383 Views)
