bluetooth read
Hy I'm a new user of this forum. I'm an italian student of informatic engineering and I working at one project for my thesis, about interfacing of a sensor to a pc with labview. My part of the program interest data backup. I have one problem. I must to use a PDA to control the sensor, the palettes that i need are the bluetooth palettes and with the bluetooth read i have one problem. The old program interface one sensor to a PC and use the VISA READ and the virtual com. In this way the program it's OK, the response of my command is that expected (values recorded in the buffer). In the new program i have to use a bluetooth read and the response is different (only the word OK like a wrong command).
Let me know if possible the various differences between the two functions READ and in the case if I can convert the bluetooth read in VISA READ
P.S. I tried to use also the virtual COM but is more complicated because the PDA does not connect its
Thank you for your help and sorry for my English
(2,805 Views)
Can you explain which kind of problem or error are you experiencing with Bluetooth Read??
Luca Gallo
Sales Engineer
(2,786 Views)
