bold/plan label
I am trying to format a lot of front panel labels.  Mainly, I have to make the first half bold and the second half plain.  I have been doing this with my mouse.  Are there shortcut keys for formating labels?
Kudos and Accepted as Solution are welcome!
(3,019 Views)
Hi jyang,
There aren't any current shortcuts for font style, nor can you currently add shortcuts for font style. The Idea Exchange has this suggestion here, so if it gets sufficient support it could be added.
Until then, unfortunately, you'll have to continue using the mouse.
Hope this helps,
Fred Visser -- SystemLink R&D -- National Instruments
(2,977 Views)
You can write a VI to do it for you, as long as you can get a reference to the label.
(2,960 Views)
