boolean switch until released counter + tick count
This treats it like a hand dryer.
Message 11 of 26
(4,290 Views)
I just started to learn the language so for now nothing is trivial but thanks for you r help.
Message 12 of 26
(4,287 Views)
I think I didn't explained myself correctly. I attached a Vi I found, what I want it to do is like this: let's say the user put the timeout1 (detection time) on 150 and the timeout2 (time without detection) on 100..If the user press the button the timeout1 value is running until it get to 150 and stops there, becuase we get to the timeout1 the led turn's on. Releasing the button will cause the timeout2 value to run untill 100 and then the led goes off. this is what I need using the Vi that is attached, I think it is just some modifications to it but I am new to LabVIEW so I appriciate all the help I can get.
TNX
Guy
Message 13 of 26
(4,282 Views)
Accepted by topic author GuyGor
This code here meets your requirements and is a lot simpler to read (no case structures!).  What I have here is using a Feedback Node to keep track of the previous value of the button.  So when the value changes (the Not Equal), the Elapsed Time function resets.  I also added a Select so that you can have two different times, one for turning on and another for turning off.  When the target time has been reached, the Time has Elapsed output will go to TRUE.  With the select, I choose to use the current button's value for the LED output.  When the time has not elapsed yet, I use the previous value of the LED output (stored in the Shift Register).
Message 14 of 26
(4,274 Views)
TNX , I want to do it with the way like in the file attached but I will look at what u sent back at home.
Appriciate your help 🙂
Message 15 of 26
(4,263 Views)
Why are you attaching the same file twice? Once is sufficient!
Message 16 of 26
(4,255 Views)
Just because I like throwing things out beside Cross. My version of the tap, without using that fancy elapsed time express. Although the event structures probably make life a little more complicated again.
Message 17 of 26
(4,249 Views)
Also, just after looking back through your code, you do realise that:
is exactly the same as
Just a little semantics thing I thought I should mention.
Message 18 of 26
(4,247 Views)
Just for completeness, here's another event based extended version of my earlier post.
(Some extra code was needed for the case where the user releases the button before the LED goes on)
Message 19 of 26
(4,242 Views)
Altenbach , please don't help me anymore . You seems to be very angry with me and for no reason at all. I am new at this forum and new to this Labview world as well, try to act appropriate.
Message 20 of 26
(4,207 Views)
