boolean triggered timed loop
Good afternoon Labview board,
I'm building code that turns a mouse click into a 2sec boolean true (indicator).   My requirements are that...
1. Once the 2sec passes the boolean switches back to false.
2. The user is unable to re-trigger the process until it returns false.
I have attached a LabView v8.6 VI.   It works, but very poorly.   It often misses the mouse click, and has an unwanted latency.
Any help improving or redesigning it would greatly appreciated!
super-neuron
(5,275 Views)
This does what I think you are looking for.
Only sets timer when going from off to on.
Omar
(5,271 Views)
Omar,
Could you save that VI back to version 8.6 or JPEG the screen shot?
Zach
(5,262 Views)
(5,258 Views)
Hi Super,
Have modified a VI i used a while back to do something similar:
I have made this into a subvi so you can use it as shown below:
I have attached both the subvi and example vi below in 8.6.
Hope it is what you need.
Lucither
"Everything should be made as simple as possible but no simpler"
(5,243 Views)
