12-22-2009 05:25 AM
I am trying to install the ETS RTOS on the desktop PC. I created USB utility drive from MAX for LabView 8.2. I am using NI PCI 8232 ethernet card.I formatted the hard-disk using the USB.
When I try to boot the PC using RTOS hard-disk, it reboots again and again. I tried to evaluate the system but it gives the following error
system error kernel.446610 : LFS Error : Not a DOS disk: pc_dskinit
It does not even boot in the safe mode. What could be the possible problem?
12-22-2009 07:00 AM
12-22-2009 07:06 AM
12-23-2009 01:35 AM
I checked the two links. As per one of the posts, I formatted the hard disk using partition magic and made the c drive active. But still the problem persists.
If I run the PC evaluator utility then atfer giving the message ".....found 1 device" the system reboots.
12-23-2009 03:07 AM
12-23-2009 04:16 AM
I checked the system configurations as per the given document. It seems that everying is fine. I have pentium 4 processor with 512 MB RAM. PCI BIOS is found. HDD is formatted using FAT32. Power rails are supported by motherboard.
But the problem still exists. When I try to evaluate my PC with USB utility, without giving any error, after loading ethernet drivers and finding ethernet device, the system reboots. Als, if I try to boot from the USB, the system says "program not found" and reboots.
12-23-2009 04:30 AM - edited 12-23-2009 04:31 AM
12-23-2009 04:47 AM
