bpsk time domain
while using modulation tool kit  i came across the problem that all the output from the modulation block (bpsk , qam etc) the output is in symbols and the constellation plot can easily be seen  but i want to display the modulated signal in time domain as a signal .?
help
Regards
(2,983 Views)
Hi Nolsqn,
Thank you for posting on the discussion forums. In order to be able to plot the modulated signal in the time domain you can use the
MT Get Complex IQ Component.vi, and then select magnitude as the CE component. Please check the attached screenshot for a sample code.
Faris A
Message Edited by Bueller on 01-30-2009 03:39 PM
Bueller
(2,933 Views)
