breakpoint continue keyboard shortcut
I prefer activating the "retain wire values" and hovering above wires during debugging to see their current value (with a breakpoint somewhere), as apposed to using probes.  This is because with the probe watch window, you have to constantly check/remember which values go to where on the block diagram, and using individual probe windows obscures the block diagram.  What I'm surprised by is that there doesn't seem to be a keyboard shortcut for the continue button (which is normally the pause button) that advances a breakpoint to the next cycle.  Such a shortcut would really help for the type of debugging I described, especially when I'm trying to quickly iterate through some cycles to get to one of interest.  Am I missing something?
Jesse
(4,258 Views)
Accepted by topic author JesseU
Ctrl-r
Jim
(4,247 Views)
Thanks Jim, works like a charm.
(4,228 Views)
