bring excel to front
Hi
how can I bring excel to foreground when doing it not on the beginning. for example after having written some data in the sheet with activeX.
I tried to set the application to visible later in the sequence but the excel windows remains in the taskbar although it is blinking.
thanks for your help
(3,366 Views)
Try the Windows Utility tools from NI.
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3EF4556A4E034080020E74861&p_node=DZ53008&p_submitted=N&p_rank=&p_answer=&p_source=External
Or, you can write some macro code in Excel utilizing the windows APIs and call it in Labview at appropriate time.
-Joe
(3,366 Views)
Try the Excel application reference with the Property Node WindowState set to write -4137.
VBA: Application.WindowState = xlMinimized (-4140)
and Application.WindowState = xlMaximized (-4137)
Michael Munroe
Certified LabVIEW Developer
www.abcdef.biz
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(3,366 Views)
You can use ActiveX to do anything:-)
(3,366 Views)
