broken sub vi link path
I got a VI with broken link to some of the sub-vi.  I want ask is there a way I can know where it is original linked from?
Peggy
(3,439 Views)
Select the missing subVI in your block diagram.  The context help should tell you where it was supposed to be.  Also, the project window should show somethings in the dependancy section.
(3,437 Views)
Many reasons have,
Is it related to NI or you created that Subvi.
If you’re not proving actual path of that VI then you will get this kind of Error.
Munna
(3,427 Views)
Are you talking about the missing sub VI? If you have 2014 version then as Tim said you will get the expected path in the context help. For earlier vresion you have to take the label and find it.
(3,404 Views)
