buffered TDMS file still very large
Hi - I've attached a bare bones version of the program which has the same problem. The "logger" vi is the main one. I've also attached some sample data. Thanks for the help
Niall
Message 11 of 24
(1,452 Views)
When I open the tdms file using the tdms->excel importer, I see that only two channels in each group have NI_MinimumBufferSize set (to 3000).  The rest are defaulting to instant writes, creating a header line at every write, blowing up your file size.
your "set buffer.vi" wasn't in the attached zip.
-Barrett
CLD
Message 12 of 24
(1,439 Views)
It turns out that the channel array needed transposing (a problem with the bare bones conversion) which I have done in this version. I have also included the setbuffer file now. I didn't realise you could see the buffer size in the excel file
Thanks again
Niall
Message 13 of 24
(1,435 Views)
which begs the question: do your production tdms files show the buffersize property for all channels?
-Barrett
CLD
Message 14 of 24
(1,431 Views)
Sorry for forgetting post my example VI previously.
I have tried your VI. The main cause it has is that it uses "interleaved" as the data-lay out input for TDMS Write. If the data to write is interleaved TDMS has to flush its buffer for each write call thus the minimum buffer size property can't take effect. The reason you see that the data seem to be "buffered" by TDMS previously is because TDMS has a default  2MB disk cache ("NI_DiskCacheSize") for "disable buffering" write. If you set the "disable buffering" to false, you will see the file size is continueously increasing by refreshing the explorer.
Message 15 of 24
(1,419 Views)
OK - so that explains why the minimumBufferSize didn't work then. Its seems odd to me - would the main time when you want to use a buffer be when you are writing interleaved data i.e. streaming real time to a file? If you can only use the buffer on non-interleaved data then you would hardly get any fragmentation anyway because you would only do as many writes as the number of channels. Unless I've misuderstood.
Do you have any recomendations for a better way to do this then? Is my only option to assign an array and then fill it up and write that to a tdms? I though the whole point of the buffering was to avoid that situation.
Thanks for getting to the bottom of that
Niall
Message 16 of 24
(1,413 Views)
From LabVIEW 2009, TDMS have a feature called "one header only", that means if you keep writing data of same data-layout ( same channels, same number of samples and same data type), your TDMS file will save "header"s and decrease file size. like the following:
If you can re-design your logging part ( try to separate your TDMS Writes from one loop and make a loop for each write) and make it fit "one header only" requirements your file size will be greatly decreased.
Message 17 of 24
(1,406 Views)
Thanks very much - I'll give this a go and let you know if it works.
Message 18 of 24
(1,399 Views)
Where are these things documented?  I am continually frustrated with how incomplete the TDMS reference materials are.
One header only: does this mean identical calls to TDMS write?  Not very useful if you need timestamps and data.
-Barrett
CLD
Message 19 of 24
(1,395 Views)
I completely agree with blawson about the help files. This is my first labVEIW program and I am amazed by how lacking the help is in general (not on the forum obv - its excellent here ;). How a visual language like this doesn't have pitures in the help is beyond me (I know there are examples).
Message 20 of 24
(1,393 Views)
