02-27-2004 05:08 AM
02-28-2004
11:14 AM
- last edited on
10-06-2026
03:12 AM
by
Content Cleaner
The answer depends on your hardare.
If you are using an NI-DAQ device you can see the examples under
help>>>Search Examples>>>Hardware Input and Output>>>DAQ(Traditional DAQ)>>>Digital Input and Output>>>...
The ... depends on the board you are using. If you can't find what you wnat there, your board may not support what you are attempting.
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
03-01-2004 02:07 AM
03-01-2004
10:32 AM
- last edited on
12-11-2024
08:44 AM
by
Content Cleaner
Hello Thijs,
The "Port List" connection of the DIO Config.VI should be wired with an array of the digital ports you wish to use. Each port has 8 digital lines.
Unfortunately, the E-series devices do not support hardware-timed digital I/O. You could still output your points in a software loop, but you would not be able to guarantee 1000 Hz. For a card that does support this, look at the 6533. For further assistance in obtaining the correct board, go to http://www.ni.com and click on "Contact NI" at the top to speak with a customer support representative.
Grant M.
