buffered operation
whats does it mean by selected lines do no support buffered operation?
(3,775 Views)
Where did you get this message. Please give your problem bit more detailed.
(3,773 Views)
Refer to http://forum.ib-berger.com/index.php?showtopic=12
there's  DIO_PWM_50Hz.LV71.zip
Question 1: How to choose the time base frequency? Any guideline for the M series datasheet?
Question 2: For the digital I/O port, can i choose any of the digital I/O?
(3,762 Views)
if i choose non pfi (digital i/o) and 20MHz timebase, the previous error gone which mention buffered operation etc)
however, theres new error mention: Sample clock rate must match the frequency of the internal timebase specified as the sample clock source
Question 3: what does it mean by "Sample clock rate must match the frequency of the internal timebase specified as the sample clock source"? where to set the sample clock rate in the vi there?
(3,761 Views)
Which one should we choose? The digital I/O (which exactly the counter on the board) or any non-pfi digital I/O line?
(3,757 Views)
please share if anybody know the answer. Every little bit help a lot. thanks
(3,739 Views)
