buffered standard deviation
Hi All,
I generate some data, and I would like to get continously the standard deviation of the last measured N double number. I do not want to get a result until I have already got at least N number from the generated data. I have attached the not yet finished test vi. I thought this should be relatively easy to do, but I feel what I try to do (I would make some modulo iterating for the index of the insert into array function, so I would always replace the oldest member in the double array) is really not elegant. Maybe someone could point me toward the proper direction.
Thanks!
(3,013 Views)
There was some problems with the above vi, I have made some modifications, I think this is a working solution. I have attached it. But my questions remains: is it a good/nice solution? In my real application I will use a double array with size approx. 1024-2048.
Thanks for any advice!
(3,007 Views)
Accepted by topic author Blokk
okey, some more search in the forum, and I have found there is a built-in solution in labview for this,
in Point by Point >> Prob & Stat :
http://forums.ni.com/t5/LabVIEW/Creating-Trendline-of-50-Period-Moving-Average/m-p/1182653
(2,993 Views)
