[bug] LV opens extra VI
This must be a bug, and it's annoying, though not critical. In my current project, when i open the main.vi, it also opens setup.vi. Every time. Why!? In other projects it doesn't, but for some reason LV finds it logical to open 2 VI's when i order 1.
Opening setup doesn't open main, ofcourse.
Any way to fix this behaviour?
LV2011
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,096 Views)
Accepted by topic author Yamaeda
Is setup.vi called from Main?
I can imagine that the call is configured for "Open front panel when loaded" (SubVI Node Setup).....
Norbert
Norbert
Expert: Geometry
(4,094 Views)
Hah! I found it! The VI had "Show front panel when loaded", which is what happens when i open the main.vi ...
No bug!
/Y
Qestit Systems
(4,092 Views)
You answered as i found it out myself. Thanks. 🙂
/Y
Qestit Systems
(4,091 Views)
