[bug] LabVIEW crashes when editing an XY Graph
Earlier, I went in to edit an XY graph that was part of the DMC LabVIEW UI Suite.  I had a misclick and was surprised when LabVIEW hard crashed. I tried to replicate with other standard XY graphs and was unable to.  I don't know what was unique about this graph produced by DMC.  Regardless, thought I'd post.
Steps to replicate:
1. Create a new VI and add the DMC XY Graph
2. Right click on the graph and do Advanced -> Customize
3. Mouse over the Plot Legend array until you can select a single element inside of the array.
4. Drag that element outside of the array.
5. Release element.  LabVIEW will crash.
Additional info:
LabVIEW 2018 32 bit f2 patch
Windows 10 Professional, Version 1803
DMC XY control is attached.
Message 1 of 11
(5,946 Views)
What do you mean when you say you were not able to replicate it?  It sounds like the issue might be in the DMC Suite, try installing the latest update of LabVIEW, or maybe try it on a different computer and let us know how it went.
Message 2 of 11
(5,895 Views)
I mean that I was unable to replicate it with other graphs.  As in following the exact same steps with other graphs did not cause the crash.
It is clearly something the DMC suite did with their graph, but that also means there's an option somewhere that they enabled / changed which allowed for this behavior.
As for trying on a different computer or updated version of LabVIEW, you're welcome to test it yourself. I included the offending control, as well as clear instructions on how to replicate it in the original post.
Message 3 of 11
(5,883 Views)
You should contact DMC and link them to this posting. I don't think that anyone else would want to mess with their source IP.
And, while the toolkit is free, DMSs terms of use clearly asks you not to redistribute.  So, ping a moderator and have the control attached stripped down please.
Message 4 of 11
(5,869 Views)
Jeff,
I thought of that before posting and double checked the webpage I linked before hand.  The exact quote is:
"We simply require that you do not re-distribute the toolkit itself."
This is hardly a redistribution of the toolkit.  As for messing with their source, they also explicitly state that is OK.
Message 5 of 11
(5,861 Views)
Can reproduce the crash in LabVIEW 2018 64bit.
Curiously, if you try to customize the Plot Legend itself, the crash does not occur. Only when you are customizing the graph control. You just have an empty array. See below.
mcduff
No crash if you pull out the plot indicator when directly customizing the Plot LegendNo crash if you pull out the plot indicator when directly customizing the Plot Legend
Message 6 of 11
(5,853 Views)
Hello mcduff,
How can you do to customize the plots legend ?
Cordialement,
Julien V.
[FIRST]
[LabVIEW Programming]
[FIRST]
Message 7 of 11
(5,588 Views)
@Julien_V. wrote:
Hello mcduff,
  1. Select the Graph Control.
  2. Choose Customize Control.
  3. In the Customize Control window, select the legend.
  4. Go to the menu and choose Customize Control.
mcduff
Message 8 of 11
(5,573 Views)
Yeah ! 🎉
I've always used right click and local menu.
In this case, I can't customize legend.
Thanks !
Cordialement,
Julien V.
[FIRST]
[FIRST]
Message 9 of 11
(5,546 Views)
In pictures, not sure what is going on.
  1. Select Plot
  2. Choose Customize control
  3. In Customize Control Window, Select Tweezers
  4. Select Legend
  5. Choose Customize control
  6. You should have a legend window.
Select plot, choose Customize ControlSelect plot, choose Customize ControlIn Customize window, change to tweezersIn Customize window, change to tweezersSelect Legend, Choose Customize ControlSelect Legend, Choose Customize ControlLegend in a customize control window.Legend in a customize control window.
mcduff
Message 10 of 11
(5,544 Views)
