build 2d array
Hello
I was wanting to build a 2d array with 10*10 element. So a total of 100 elements. The top left corner of the element is to be 0 and the bottom right is to be 10. Each element will increase from the last by 0.1 . Is there a way to build this quickly instead of filling in every value. I would like it to look like this.
0,0.1,0.2,0.3,0.4,0.5,............
1,1.1,1.2,1.3,1.4,1.5............
2,2.1,2.2,2.3,2.4......... and so on
Any Help would be appreciated
Thanks Craig
(3,317 Views)
Accepted by topic author Craig1988
Hi Craig,
using some basic math:
But in the mean time you should have typed an array constant instead Smiley Wink
(3,309 Views)
