build a conditional look up table
Hi
I'm using a 7.1 ver.
I want to build a conditional look up table, my data include two corresponding values; Volt an Watt which i got from measurements that i had. If it was a regular LUT there was no problem (i saw a perfect solution for a regular LUT:    https://forums.ni.com/t5/LabVIEW/Creating-Lookup-table-in-Labview-7-1/m-p/506600?query.id=102139#M24... )
i need for each transformation to choice a different table, based on the frequency that i use. - that's the problem for me.
i attached the measurements file for more information.
note that the inputs is volts and the output is Watts, and the conditional is Freq.
thanks and hopping for ideas.
(3,146 Views)
You can use Ben's example by extending it and performing a double lookup. If your arrays are always of the same length, you can simply have a 2D array and extract your element from it by wiring in your two index arrays and searching both of them. If your arrays can have different lengths, create a 1D array of clusters where the cluster holds a 1D array. This will allow each internal 1D array to have a different length.
___________________
Try to take over the world!
(3,142 Views)
but HOW???
i have a lot of info!!!!  the file i upload is not all of it. i have massive amount of data.
if i work at the same way and put all of Ben's vi into another for/while then it work with the wrong data.
how i change the "sub data" for the 2nd dimension (for different Freq. value)????
i can't see the solution.
by the way - i'm pretty much a beginner in labview so maybe because if this i can't see it happen.
and another question: why my for/while loop don't stop the "random number" function???
thanks
(3,127 Views)
Here is a very quick example which shows the concept.
I'm not sure what you mean by that. The random number function just outputs a random number once, regardless of where it is called.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
(3,118 Views)
