build array
I would like to build an array without including any information that has been set to 0.  For example the numbers: 25,13,63,42,0,8,2 would be an array such as this:
25
13
63
42
8
2
If I use the classic build array function, the 0 would be passed because I am taking the numbers from local variables.  It would look like this:
25
13
63
42
0
8
2
Any help would be appreciated
-ncm
Message 1 of 9
(4,813 Views)
Accepted by topic author ncm
Use simple case structure and comparison to check and then build array.
Check this http://208.74.204.114/t5/LabVIEW/delete-0-from-array/td-p/2052658
-You need to upload what you have done also to give better idea.
uday
Message 2 of 9
(4,802 Views)
Well, you need to show us your "classic" code, because we have no idea how your code is architected. This way we can easily tell what needs to be done. How are you currently building the array?
Typcally you would keep the array in a shift register, place the "build array" inside a case structure and wire the other case across.
If you have a newer LabVIEW version, you can also use conditional autoindexing tunnels.
Why does the value come from a local variable? What's wrong with using the terminal?
Message 3 of 9
(4,799 Views)
Thanks!  I am terrible at finding stuff in the forums, this was a great help!!  I knew it should be simple =D
-ncm
Message 4 of 9
(4,783 Views)
I would recommend against the code shown in the linked thread. That was about removing zeroes from an existing array while you seem to be struggling not to even add them to the array in the first place. 😉
Repetitive use of "insert into array" is very inefficient and can cause huge performance penalties of the arrays are large. There are much better in-place solutions.
Message 5 of 9
(4,771 Views)
I would recommend against the code shown in the linked thread. That was about removing zeroes from an existing array while you seem to be struggling not to even add them to the array in the first place. :smileywink:
___________________________________________________________________________________________________________________________________
I would definitely use any suggestions that I can take, if you have others, I love learning Smiley Happy
I am only working with at the most 5 numbers but if my arrays get large, I can tell the code would not be good.  I used Search 1D Array and Delete from Array and repeated this 5 times (extremely inefficient)  It is just a little quick program I am throwing together but if I want to build on it in the future this would be problematic.
-ncm
Message 6 of 9
(4,750 Views)
Please check this, one way to optimize https://www.ni.com/docs/en-US/bundle/labview/page/in-place-element-structures-increasing-memory-effi... (i think this is what altenbach suggesting)
uday
Message 7 of 9
(4,745 Views)
This link has really nothing to do with this discussion. An in-place solution rarely requires the use of the "in place element" structure.
If you have an existing array and need to remove elements matching a certain pattern (e.g. =0), you should could do something like the bottom example linked in my idea here. (while you are at it, vote for the idea! :D)
Message 8 of 9
(4,738 Views)
Sorry, if it was misleading this discussion.
-I was thinking of multiple copies of large arrays as problem there and posted that in-place element usage. Sorry for that.
uday
Message 9 of 9
(4,722 Views)
