build exe
This is new for me.....I hadn't that kind of message. The error message I obtained is that one I posted
yesterday.
Just to be clear, if you building up an exe file from the vi and you run it:
1) the exe program let you choose the edf file
2) in the outup line of the exe program it seams it create the file export.edf.tdms
but if you check into the folder the .edf.tdms file is not there and the program return to you the error message you send me
is it right
Message 11 of 16
(995 Views)
I got "Error -2564 occurred at Invoke Node in _openDataStorage.vi->_openWithRoot.vi->_openStorageWithRootNoPluginCheck.vi->_openStorageWithRootAutoDetect.vi->Convert to TDM or TDMS.vi->EDF-TDMS Converter GC.vi Connect data storage" when running the VI.
If running List Data Plugins (as mentioned in the read TDMS help) i didn't have any EDS-plugin.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 16
(987 Views)
Sorry but I don't understand...do you mean that it works?
Please tell me it works... 🙂
How can I run the List Data Plugins?
Message 13 of 16
(984 Views)
Message 14 of 16
(984 Views)
No, i cant read EDS files, since it requires some data plugin.
/Y
Qestit Systems
Message 15 of 16
(972 Views)
However could you tell me how do you run the list data plugins?
Message 16 of 16
(966 Views)
