build hexadecimal string into byte array
My end task is to send commands over UDP to an FPGA. The commands are available in Python script.
I haven't worked with byte arrays for years and am looking for some help.
Attached is LoopThroughItemNumber.vi  I want to replace the hex value in column 5 to change a setting.
I manually created the array that works but am struggling with code to do the same thing. Thank you in advance for looking at this.
Message 1 of 15
(4,840 Views)
Hi kierzie,
unfortunately I cannot open your VI due to its LabVIEW version, but maybe this can help you:
Message 2 of 15
(4,784 Views)
Hi GerdW,
Your answer helped. Attached is a new file saved for LabVIEW 2021. I apologize for not thinking to do that with the first post.
In the 2021 version I added code to change the item number.
Thank you for your help!
kierzie
using LabVIEW 2023 on Win10/11
Message 3 of 15
(4,752 Views)
Accepted by topic author kierzie123
If I understand the problem correctly, here's what I would do:
Message 4 of 15
(4,741 Views)
@altenbach the scan format should be 0x%x instead of 0x%d.
Message 5 of 15
(4,731 Views)
Or this:
Message 6 of 15
(4,708 Views)
Thank you very much! We will be using array index 5 because of the way the embedded engineers wrote their code.  What I need to change is in the second byte of the U16.
raphschru's advice to use 0x%x will probably work as well.
The replies helped me get past a huge roadblock.
Message 7 of 15
(4,703 Views)
This solution works also, once I changed the array index from 4 to 5!
Message 8 of 15
(4,702 Views)
Sorry yes, small typo. (Of course it does not make a difference if all numbers are very small has seen here). 😄
(I edited my post to avoid confusion in the future)
Message 9 of 15
(4,675 Views)
Just for fun, this minimal code works too... Less pink! 😄
Message 10 of 15
(4,641 Views)
