build specifications menu empty
Hi there,
Im currently trying to create a dll from a Labview project, following the instruction from this webpage : instructions on creating a dll from LV.
My problem is, when I right-click on "Build Specifications" I only have one item to choose from the "new" menu, which is "Source distribution".
How can I get the other options ? (I had the same frustrating problem when I tried to create an executable file).
My version of LV is 11 btw.
Thanks in advance for any help 😉
(3,122 Views)
Hi Johndoe77651244,
Do you have application builder installed into your computer?
You will need it to create a dll.
More information of application builder can be found from the below link,
https://www.ni.com/en-us/shop/product/labview-application-builder-module.html
TuiTui
(3,109 Views)
