build waveform of x and y values
Hi
I have a time and data column. I need to build a waveform with those values. But the time values don't have a similar stepwith.
After this a want to increase the number of values by interpolating them.
How can I handle this problem?
Thanks for any help
Yves
(2,838 Views)
Hi Yves,
here is an example for you.
Mike
Message Edited by MikeS81 on 06-03-2008 02:22 PM
(2,825 Views)
Hi Yves,
If I understand properly, you need to display your data in XY Graph.
To understand how to use XY Graph, check Example Finder and try to search for XY Graph. You coul also check attachet VI which demonstrates how you could use XY Graph.
Martin
(2,822 Views)
