build waveform problem
I am have a difficulty with the LabVIEW vi "build waveform" i wired all the inputs on the vi: dt, t0, and Y, i have correct time stamp, but when connect it, my waveform keeps saying it is 01/01/1904?
I've tried my time stamp on the example vi: Create Waveform example, and there it works? I don't get it? What am i doing wrong??
In the attachment my vi
Thijs Boeree
(2,782 Views)
Accepted by topic author ThijsBoeree
I don't see your problem.  If I enter a valid timestamp into your BDF header, then run your code, I get the same timestamp out in the waveform.  Specifically where is your problem?
(2,762 Views)
I forgot to turn off "ignore time stamp" then it worked... Smiley Frustrated
Thijs
(2,758 Views)
