03-02-2006 06:34 PM
03-03-2006 05:15 PM
10-06-2006 01:27 PM
10-09-2006 04:42 PM
10-10-2006 08:30 AM
10-11-2006
04:03 PM
- last edited on
08-18-2025
08:11 AM
by
Content Cleaner
Hello hellolv,
When using NI-DAQmx Base to program data acquisition applications for PDA, there is a slightly different method for creating and configuring tasks that does not use the typical Create Channel and Timing VIs. Instead you should use the NI-DAQmx Base Task Configuration Utility to configure your task. You can access the NI-DAQmx Base Task Configuration Utility within LabVIEW under Tools > NI-DAQmx Base Task Configuration Utility. For more information about how to properly configure your task, take a look at the Create and Configure Tasks section in the following guide:
NI-DAQmx Base 3.x Getting Started Guide
I hope this information helps and let us know if you have any further questions.
Travis G.
Applications Engineering
