building a .net 2.0 assembly with labview 2014
I am programming a C# application with the .NET 2.0 Framework (.NET 2.0 is a requirement for compatibility).
I want to use funcitonalities of a LabView VI, so I built a .NET Interop Assembly and reference it in my Visual Studio 2012 C# project.
Visual Studio doesn't accept the namespace of the reference and I get this build error:
So the build result has a dependency on mscorlib assembly from the .NET 4.0 Framework....how can I configure Labview to build an interop assembly which targets the .NET 2.0 Framework?
 Thank You.
(3,806 Views)
Accepted by topic author Simorgh
Hi Simorgh,
You can find the instructions to make LabVIEW generate .NET 2.0 Interop Assemblies in the following KB:
Configuring LabVIEW to Generate .NET 2.0 Interop Assemblies -
http://digital.ni.com/public.nsf/allkb/645374D70C04B47386257CCB0065B8B4?OpenDocument
I hope this helps.
Maha
(3,783 Views)
Thank You Maha!
It works.
(3,714 Views)
