burning VI on C6416 DSK from labview
hi,
i am trying to dump my labview vi(code) on c6416 DSK. i have installed labview dsp module and every thing is working, it also shows c6416 in the target.
when i simply run/execute the vi, it runs perfectly, but when i try to burn that same vi on the kit, it shows errors.
is there any special requirement for burning vi's on c6416 dsk. kindly guide.
regards
(3,132 Views)
i am trying to dump the vi's for QAM modulation to the dsp kit. during the simulation the QAM vi's run successfully.
do i have to change some inputs or outputs in the vi's for dumping purpose or should the code used for simulation should be used for dumping also.
regards
(3,126 Views)
Hi asif2133,
Did you use the Build Specification in the project?  Directions can be found here:
http://zone.ni.com/reference/en-XX/help/371300D-01/lvdsphelp/dsp_flash/
(3,091 Views)
