bus monitor function in NI - XNET
Is CAN bus monitor function available in NI- XNET 1.1.3 palette? If not is there any way around to bring the bus data stream to the front panel?
Thanks.
(4,574 Views)
There are two ways to access the bus monitor, you can access it through Measurement & Automation Explorer as discussed in this KnowledgeBase: http://digital.ni.com/public.nsf/allkb/29B1BA306ADB423A8625761800594631?OpenDocument
Or you can use an example from the LabVIEW Example Finder titled "CAN Input Stream to TDMS Logfile.vi". You can remove the option to write to a TDMS file and just monitor the input frames on the front panel. To locate this example
  1. Open the LabVIEW Example Finder
  2. On the Browse tab, expand "Hardware Input and Output" >> NI-XNET >> Logging and Replay >> Can Input Stream to TDMS Logfile.vi
I am attaching a screen shot of the block diagram to give you a better understanding of what the example I am referencing does.
I hope this helps.
Regards
(4,556 Views)
How do I go about removing the option to remove the programs ability to write to the log file? I have been trying to delete a few things within the program to disable to feature because I only want to display the messages being exchanged on the front panel.
(3,912 Views)
Just remove the functions that create the TDMS file, write to it, and close it.
(3,900 Views)
