button library ???
where could I find a bookstore of buttons?...for labview
thanks
Message 1 of 10
(6,946 Views)
Could you elaborate a little more on your question?
Are you referring to LabVIEW boolean controls?
Jonathan Hildyard
Applications Engineering
Message 2 of 10
(6,946 Views)
Yes, I refer quite to this.
I search pulsating with standard icons... floppy disk or save, copy,
printer, ok, enter, exit, forward,stop,.....
thanks
"Jonathan H" ha scritto nel messaggio
news:5065000000050000003E7B0000-1021771306000@exchange.ni.com...
> Jonathan Hildyard
> National Instruments
Message 3 of 10
(6,946 Views)
There are no standard icons such as save, copy, etc., available from National Instruments. I believe you are searching for Microsoft Windows/Office icons that are registered under the system32 folder on your computer.
Message 4 of 10
(6,946 Views)
These custom controls downloaded from OpenG site.
Message 5 of 10
(6,946 Views)
You may wanna try customise your controls.
First
In a new vi, insert a boolean control i.e. Square Button. Right click on the control> Advance> Customise...
Sencond
~ Double clicks on the Top-right corner's icon of the panel, edit the icon in accordance to your preferance i.e. EXIT picture etc.
~ CTRL+C to copy your icon to the clipboard, OK the dialog.
~ Go to Edit Mode for the control (TOOL icon button), right click on the center of the Button > Import piture...
By now, a Control with your own created icon is ready for use.
Hope this will help.
happy trying
~ ian.f
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 6 of 10
(6,946 Views)
I have done like you have told, but it is not possible color the button.
why?
is there a way for behavior this?
tkanks
Message 8 of 10
(6,946 Views)
I suggest that you keep the button's colour original in your customisation.
By importing your customised button into a new vi, you can change its colour by simple select the colouring-tool and right-click on the button (you will be able to pick your colour from a pop-up colour picker).
It works, believe me 🙂
Cheers
Ian F
依恩与LabVIEW
Message 9 of 10
(6,946 Views)
Like this?
LabVIEW, C'est LabVIEW
Message 7 of 10
(6,946 Views)
I have created these... try them out.
Colour is possible.
ian.f
Ian F
依恩与LabVIEW
Message 10 of 10
(6,946 Views)
