button picture item
Hi
How can I control the picture item of a button? Since a button has 4 picture item under Customize, can I pass the value 1 to the button programmatically so that the button will display the picture item 1... ?? THanks
Message 1 of 14
(5,109 Views)
are you talking about a 'picture ring' control/indicator??
Message 2 of 14
(5,090 Views)
I'm talking about the OK button... Because I couldn't find a property to control the picture item which I changed it from the Customize.. Thanks
Message 3 of 14
(5,086 Views)
No, You cann't set it programmable, it is hard set by customization.
________________________________________________________
Try to make everything Automatic
Message 4 of 14
(5,081 Views)
Moreover, the control you're referring to ('OK BUtton') is a boolean with 2 states (true and false), the four pictures you're referring to are the following:
False,
True
transition False to True
transition True to False
(i'm not sure of the order)
If you want to contol the pictures you'd better use the picture ring, or a seperate picture item (Have you thought of X-Controls?) They look like the perfect tool for you..
Ton
My LabVIEW Ideas
Message 5 of 14
(5,075 Views)
What I wanted was when the user point (mouse over / enter) to the OK button, the picture of the OK button will be changed.. Is it possible for OK button? I know how to control picture ring but not the OK Button..... tq
Message 6 of 14
(5,071 Views)
For this goal, that you can use a picture indicator, let an "OK" button over it. and make the OK button is transparent, as the mouse on it, event structure call picture image....
if you don't know how to make it, that I can make a simple sample for you reference.
Message 7 of 14
(5,071 Views)
Hi Yukee..
Could you pls make an example from your explanation? I didn't get it.. Smiley Tongue Thanks
Message 8 of 14
(5,067 Views)
OK. enclosed
Message 9 of 14
(5,068 Views)
THANKS YukeeSmiley Very Happy
Message 10 of 14
(5,063 Views)
