09-02-2020 03:39 AM
@Eric1977 wrote:
To add what GerdW stated, you should...
- Right click on where the Boolean input is in the While Loop and select "Replace with Shift Register"
- Wire across (most likely) the stop button's output to the left side of where the other shift register would be on the left side of the while loop
- Change the conditional terminal in the while loop from "Continue if True" to "Stop if True"
Beyond that, it looks like you have is a Simple State Machine. Look into that once you have this working the way you want.
Hi Eric thanks for the help.
I tried to open your file, but my labview version is 17 while you use 18 as far as i can see.
Can you resend it with compatibility to older version please? 🙂
09-02-2020 07:02 AM
Here's version 17.0
09-02-2020 10:12 AM
Thanks again for replying Eric, but the file has not been sent 😅
09-02-2020 10:33 AM
Try it now.
