buying labview programme on sensor
anybody willing to help me do a sensor programme using labview to controll the limits of the motor movement ??
the sensor is
GP1S53VJ000F.
we are using EPOS2 50/5.
(3,541 Views)
Whats exactly your requirement?
You would like to know how to develop the code for the appication or you already have a design which requires tuning.  Post the requirement clearly so that forum can help out.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(3,527 Views)
(3,521 Views)
Hei sorry for the double post.
My project main task is to use labview to control a humanoid robot. So therefore, i got to make the motors in the robot run. I have the labview programme for making the motor run completed. Now, i need to add in the sensor to my motor control programme. This is the datasheet of my sensor http://sharp-world.com/products/device/lineup/data/pdf/datasheet/gp1s53v_e.pdf
My sensor is connect to J5 of the EPOS 2 50/5. I am using the sensor to limit the movement of the robot. Can u either teach or help me do the adding in of the sensor in labview? I have tried many ways to let labview read the sensor but still no progress.
(3,482 Views)
(3,444 Views)
