byte conversion
I'm trying to send the number -8 in decimal (i8 representation)  to an external device using visa write. However, when I use the typecast function to convert -8 to a hex string, it converts it to the unsigned equivalent which is F8 in hex and 248 in decimal.
Any way around this happening?
p.s. I posted this question a few days ago in the biobench section by mistake so sorry mods if this isn't allowed but I thought it would be moved to the LabVIEW section.
(3,376 Views)
And what number (in hex) did you expect to see ;).
Take a look here http://en.wikipedia.org/wiki/Two's_complement
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,373 Views)
Good question, here was me thinking I'd never need to understand two's complement when I was studying it... Thanks for the input, I'll have a look at the wiki page and hopefully the solution should be straight forward enough from there.
(3,365 Views)
