bytes array to double words array
I have an array of bytes. I need to take 4 bytes at a time to create a doubleword (32bits).
I am currently using Decimate Array and Join Numbers twice to do this.
Is there a more efficient way of doing this that I am overlooking?
Message 1 of 9
(8,256 Views)
You can use get array subset VI get array subsets of 0-3, 4-7, etc etc and type cast. Don't know if this is more efficient, but is another way.
Message Edited by for(imstuck) on 06-14-2010 02:34 PM
Message 2 of 9
(8,251 Views)
There is indeed. Just do it directly:
Note: This assumes no need to perform endianness manipulation. In that case you can use the Unflatten From String function, though that would require a detour to go to a string.
Message Edited by smercurio_fc on 06-14-2010 02:44 PM
Message 3 of 9
(8,243 Views)
I would like to see the underlying code behind the Type Cast function.  It does so much.  Hmmm.... maybe I don't want to see it after all.  Smiley Surprised
- tbob
Inventor of the WORM Global
Message 4 of 9
(8,238 Views)
Doh, duh.
Message 5 of 9
(8,224 Views)
Doh, duh.
Ditto.
Will give it a try tomorrow.
Message 6 of 9
(8,220 Views)
I do have to perform endian manipulation. The information is little endian. My original information is a string from a TCPIP read. My current attempt is to convert it to a bytes array.
Can you explain in more detail what I would do in this case?
Message 7 of 9
(8,166 Views)
Accepted by topic author nyc_(is_out_of_here)
nyc wrote: I do have to perform endian manipulation. The information is little endian. My original information is a string from a TCPIP read. My current attempt is to convert it to a bytes array.
As I noted, you can use the Unflatten From String. Since the data is coming from a TCP Read you can wire that directly to it:
Message Edited by smercurio_fc on 06-15-2010 09:19 AM
Message 8 of 9
(8,155 Views)
Got it!
Thank you.
Message 9 of 9
(8,144 Views)
