bytes at serial port
Qusestion : while using visa functions i am using the property bytes at serial port . problem is some times i am getting bytes correctly and some times the output of bytes at serial port is 0 . what might be the problem.
I gave delay also 500 seconds to read and termination character as false , time out 500 ms .
help me out
Message 1 of 12
(8,357 Views)
It is difficult to help without more information.
What kind of device or instrument is it? Does it stream data or does it use a command/response system?
Are you sure the instrument is sending data when you see 0 bytes at port?
Please post your code.
Lynn
Message 2 of 12
(8,351 Views)
Here is the code . I am using this as a sub.vi to my main code . so i am not attaching main code i am just attaching sub.vi
I am using Rs 232 serial communication . ( modbus protocol )
I this code some times when i send the request output response is coming correctly and some time bytes at serial port
are zero. this is happen reguarly.
I attached my crc code also what i am using .
Message 3 of 12
(8,347 Views)
I cannot open your VI.  Can you save it for a previous version (10)?
Lynn
Message 4 of 12
(8,339 Views)
 I dont know How to do conversion but i will try as soon as possible and i will post again .
presently i am using labview trial version for 30 days
Message 5 of 12
(8,323 Views)
File>Save For Previous Version.
Why aren'y you using NI's Modbus Library?
Message 6 of 12
(8,320 Views)
Thank you  sir.
Here is the converted code to 10 version.
As a begginer of labview i dont know what is ni modbus library
Message 7 of 12
(8,313 Views)
i occasionally got the same problem for serials communications, and i don't think this phenomenum comes from application level.
i solved them via simply replacing the serials cable or serials-usb cable by a more conductive one.
Message 8 of 12
(8,302 Views)
@mahi108 wrote:
Thank you  sir.
This
Message 9 of 12
(8,295 Views)
Read fix number of bytes instead of byte at port node.
PBP
Labview 6.1-2010
KUDOS ARE WELCOMED
PBP
Labview 6.1 - 2019
Message 10 of 12
(8,253 Views)
