c++ code to labview vi
 Can u pls convert this c++ code to vi labview ??
int main(int argc, _TCHAR* argv[])
unsigned long loopCounter = 0;
unsigned char flash = 0;
char numModul = 0;
if (!Init())
std::cout << "Error \n";
return 1;
std::cout << "(c) 2014  \n";
(3,257 Views)
Hi prp,
why can't you do this on your own? (After 6 weeks in the forum you should have learned enough about LabVIEW for this task!)
Why should we do your work?
Your code consists of an IF-THEN-ELSE statement and some text display. Shouldn't be that hard, even for a beginner…
(3,238 Views)
