c project in labview
i have one project developped using c code, this project is composed with 4  .c files ( each one with its .h file), in the 5th file i have the main()  function with other functions, before asking here , i have been reading this
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4puCAA&l=en-US     , https://forums.ni.com/t5/FIRST-Robotics-Competition/Using-C-amp-C-in-LabView/m-p/3371746  and  https://forums.ni.com/t5/Example-Code/Using-Existing-C-Code-or-a-DLL-in-LabVIEW/ta-p/3499233
my question is :
there is any way to convert my project developped in c to labview ( not a function ( to dll) but a project which contents a lot of functions with one main()).
thanks in advance
(2,819 Views)
There isn't a program, that I've ever heard of, to convert a C program to LabVIEW. Creating a .dll from a C program, that is then called from LabVIEW, yes. If you have sufficient understanding of how your program functions, you can then write a LabVIEW program to do what it does, in many cases.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,803 Views)
Hi Mikhailether,
Based on your post, it looks like you may be attempting to port your project to an embedded target.  If so (and the hardware you're using is compatable), you may also want to take a look at the Inline C Node  ( https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/properties-and-methods/vi-server/generic/g... .)
Tom L.
(2,771 Views)
