cDAQ 9181 can't be discovered under labview 2015 in order to deploy the code to device?
Hello
I am having trouble discovering the cDAQ 9181 under Labiew circled blue pic below  in order to deploy my application named Flometer2.  I can see the network device under MAX circled red pic below.
(2,545 Views)
The cDAQ-9181 is not an RT device. You can't deploy code to it.
You can use DAQmx to access your NI-9208 module.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(2,501 Views)
