cDAQ-9188 Ethernet connection problem
We bought 2 cDAQ-9188 and I am having trouble getting them to connect to the PC through the Ethernet. I can get them to work if I use a short cable (10ft) but the location I need them at is about 180ft away. When I do right click network devices and select find devices it comes back with nothing found. Would there be any suggestions on what I might have wrong or what I would need to do to get them to work? I am running LabView 2010 SP1 and the drivers that came with the cDAQ-9188 units.
(3,492 Views)
I would check to see if the long cables are good (wired correctly).
(3,487 Views)
Do you have another network ready device such as a laptop that you could plug in at the end to check the connection?  Are these units connected to a hub at all?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(3,483 Views)
Accepted by topic author antique
Evidently the Ethernet card in the PC we are using is weak. I have connected them to a router and placed the router close to the PC and they are now working great.
(3,462 Views)
Glad to hear it.  Don't forget to mark your last post as the solution.
(3,457 Views)
