cDAQ module to genarete 5 to 2000Hz signals
I am looking for a cDAQ output module which can generate 0 to 2000Hz frequency signals
Prashant
(2,411 Views)
Accepted by topic author UPRR
Hello UPRR,
As long as the module has an update rate higher than 20kS/s then you should be fine. so NI 9263, NI 9264, NI 9265 and NI 9269 should be fine for you.
Miriam
Field Applications Engineer
NI Colombia
CLD
(2,399 Views)
