cDAQ not running with executable/installer
Hi chuggins.
Like Wayne said, I'd recommend you to test the panels from MAX to see if you can get voltage readings from there.
Also, could you post your entire project?
Regards.
Aldo H
Ingenieria de Aplicaciones
Message 11 of 26
(1,496 Views)
Just to verify, I should be seeing the hardware twice in MAX on the target comuter under the Devices and Interfaces folder.. once for it just seeing it when I ran MAX and once for the configuration I loaded from my installer?  Should the configuration report show all of the channels I'm using?
...and to test in MAX, I'm assuming we're talking about making a Task and pointing it to one of the channels that I know I should be getting a voltage signal to?
Message 12 of 26
(1,492 Views)
You're exporting the MAX configuration that you created for your DAQ Assistant right?
In that case you have to make sure that the device is exactly the same and assign the configuration to the device. You should not be seeing it twice. Here's a link about exporting configurations, hope it helps you troubleshoot: http://digital.ni.com/public.nsf/allkb/A8C7C36B567DA00C8625754500026747?OpenDocument
To test in MAX just go to your device and click on "Test Panels", try to read from there.
Again, it would help me a lot if you post your full project so I can see exactly where the issue is.
Regards
Aldo H
Message 13 of 26
(1,484 Views)
Doh, sorry about that...  project should be attached.
C
edit!  Thank you for the link, I'll do some reading and see if I missed anything!
Message 14 of 26
(1,482 Views)
Can you send me the whole project with all of its files in a zip folder please?
Aldo H
Message 15 of 26
(1,478 Views)
Aldo,  I'll send them your way when i get back to work on Monday!
C
Message 16 of 26
(1,468 Views)
Aldo, what's missing from the project file, if I may ask?   I looked in it and all of the VI's appear to be attached.  I've never sent one out before so forgive my ignorance if I'm doing it wrong.  Thanks.  C
All, Ok, I ran MAX on the target computer and ran Test Panels... I can get it to give me correct data on one configuration(the "as found" config), but not the other(the loaded config).  I do have the modules renamed so that may be part of the problem.  Would the solution just to rename them in the loaded configuration to match the "as found" configuration?
Thanks guys!  The help is much appreciated!
C
Message 17 of 26
(1,458 Views)
The .lvproj file is just a text file that defines the VI's that make up the project.
It doesn't actually contain any VI's.  They are separate files.
Message 18 of 26
(1,448 Views)
AH!  Thank you Ravens Fan!   Aldo, I'll bundle all the VI's up and send them your way!
Thanks!
C
Message 19 of 26
(1,439 Views)
Aldo,
Do you have the PID & Fuzzylogic tool box?
C
Message 20 of 26
(1,429 Views)
