cDAQ w/ PTP/IEEE 1588v2
I am hoping some of you could help me understand how best to time-synchronize the cDAQ 9189 v 20.0 with an external reference clock. I do not have a TSN-enabled network but I do have a PTP clock on my network supporting PTP/IEEE 1588v2. It looks like TSN-support is enabled by default in cDAQ and I need to switch it to PTP:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019S3eSAE&l=en-US
The problem is that I am using Flexlogger and not Labview, as required in the instructions. How can I switch cDAQ to PTP? Once switched, will it automatically detect the master clock/IP or is there something else to be done to configure PTP/IEEE 1588v2 clock and PTP parameters?
Thanks for any suggestions!
Kai
Message 1 of 1
(1,028 Views)
