cRIO 9004 web server
The target in the project in this case is your cRIO controller (cRIO-900x). In the LabVIEW project, each platform that can run a LabVIEW VI, such as your Windows computer, the RT processor on cRIO and the FPGA on cRIO, are considered separate targets.
You can right-click these targets in the project and change their specific properties. See the following images.
Message Edited by Christian L on 01-31-2007 09:41 AM
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
Message 11 of 15
(3,342 Views)
ok perfect i've done it Smiley Happy
now i have only another question:
when i click the buttom stop on the html page it stops not only my program but also the connection with cRIO, while if i simply close the page html and then i open again i found my cRIO working. the question is: is it possible to  be always connected with the cRIO after i've clicked on my stop button?
I ask this question because i've seen that once i've clicked on the stop i have to set again the web server losing all the formulations that I had done before.
tnx again
Message 12 of 15
(3,336 Views)
i've tried to  launch the Web Server and to see if it works also on another pc where i don't have the VI RT.
well if for example i write cRIO Web Server SUN on te pc where i have the VI RT works perfectly while on another pc the only thing that i see is the cRIO Web Server SUN that i've written...but not the VI...why?
tnx for replies
Message 13 of 15
(3,303 Views)
I don't have understood what do you mean with " write cRIO Web Server SUN " . What can i say is to verify the setting in WebServer:VisibleVI category of properties.
Clara
Message 14 of 15
(3,286 Views)
Maybe someone can help me with this one:
I have LV 8.2.1 and a cRIO 9004, and I want to monitor the RT executable with a webbrowser.
I follow every step in this documation:
http://digital.ni.com/public.nsf/allkb/7FEE6BCFD264175C8625723E000D928E
I  enable the webserver, build the application, set it as startup and deploy it to the RT target.
Then I create the html file and copy it to the C:\ni-rt\system\www  folder.
After the reboot I want to connect to the RT with a browser, but im always getting a connection timeout error.
It looks like the webserver is not running properly (I can ping the cRIO).
Is there anything I'm not doing properly?
 Many thanks in advance
Message 15 of 15
(1,183 Views)
