cRIO 9004 with the modules 9215 and 9263
I use the cRIO 9004 with the acquisition module 9215 and 9163 to signal output, my program acquires the signal and processes correctly, but I can't do the signal exit by 9263. My algorithm is correct, I just need to connect the output terminal of the processed signal the exit of cRIO (9236).
I'm posting two files, 001.zip contains the code without the exit (9236), if somebody know how to do, please theach me.
In the file 002.zip contains the code that I modified, I don't know if it's right.
My e-mail is denilson_paiao@hotmail.com, I'm student of industrial automation in Brazil, so sorry for my English.
(2,751 Views)
somebody could help me?
(2,714 Views)
Denilson,
Check the LV example "Analog Output - cRIO.lvproj"
That example shows you how to write to analog out channels on a cRIO module.
Dario Camargo
NI Brazil
#1160271
(2,661 Views)
