cRIO-9012 add software error
I am using Measurement & Automation Explorer 2016,cRIO-9012
The problem I am facing that the device is found and connected in safe mode but when I want to add software got error as in the screenshots.
I do not know how to proceed?
(1,310 Views)
(1,270 Views)
According to this, the cRIO-9012 is only supported up to CompactRIO 18.6 and LabVIEW 2018SP1. Not sure which one is really correct. I stayed with 2018SP1 in the past.
NI-MAX 2016 should be fine, but you need to have also  a compatible version of CompactRIO installed to be able to do anything with a cRIO chassis.
Rolf Kalbermatter  My Blog
(1,261 Views)
I have upgraded NI system configuration API to 18.0 (there is no 18.6 in the list and 18.5 is 32 bit)+ compactRIO driver 18.1 but still can not add software.
Labview 2018 SP1 only runtime is available ,if I want the full edition I have to buy it, therefore I need to know the specific versions to run CRIO-9012  to be bought.
(1,242 Views)
This is my set and the list of software that I have,is there any hint to work cRIO or PXIe
(1,230 Views)
