cRIO 9014, FPGA compilation error
i am using cRIO 9014, in that while compiling the code in FPGA i am getting attached error.
please guide me ob that ......
Prashant Soni
LabVIEW Engineer
(3,004 Views)
Accepted by topic author Prashant_S1
Hi Prashat,
The error displayed is clear.
Your system time is older than Install time.
Change it to correct time and try it...
Also, if you change your system time (i.e computer time), some softwares will not work. (one more example is Gmail. Try to log into Gmail after settting year to previous year in your system time. It will show SSL error.).
(2,993 Views)
