cRIO-9014 controller ,cRIO PB , cRIO 4215
If I have cRIO-9014 controller ,cRIO PB , cRIO 4215 , How do the  cRIO-9014 controller can be communicated with MVI56 PDPMV1 through controller tags of 1756-L73 ? Could you give me a simple example.
What is operation system window in cRIO-9014 controller?
How I configure cRIO-9014 controller to communicate with  cRIO 4215 I/O ?
(2,773 Views)
Hello Rig,
It sounds like you are already getting assistance from the PSE at this other thread. Please keep a single thread per issue so that we can give you better support.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(2,741 Views)
